Firstly, hopefully this is a relevant topic for this forum. While attaching wooden shelves to a block-built internal wall recently I remembered my dread of trying to drill accurate holes in masonry. The drill bit often wanders off my mark - sometimes this is not a big problem but these shelves have 4 pre-drilled holes and if each hole in the wall is even just a little bit out then fixing the shelf becomes a real pain (and less stable too). It worked out this time, but only just.
The drill I am using is a corded 8yr-old Skil 650W, and the bits that I am using (6mm and 8mm) are, I believe, of reasonable quality. I generally turn off the hammer action while drilling through the plaster skim layer, and when I hit the block layer I stop the drill, turn the hammer action on and put the drill on the higher of its 2 speeds. But the bit seems to have trouble getting a start in the block layer so it often ends up going in at the wrong angle or wandering off centre (and widening the hole in the plaster in the process).
I'm not sure whether the problem is that the drill is under-powered (or just poor quality maybe), that the drill bit isn't good/sharp enough, that I am not controlling the drill properly, or that I am using the wrong technique. Or maybe it's all four! I've considered buying a new (corded) drill with an SDS chuck in the hope that this will help, but I'd be grateful for any advice on whether the drill itself is likely to be playing a large part in the problem.
