trials_guy
Hi Guys,
I was after some help with my dust extractor please. I have a record dx1000 which is connected around my shop using 100mm hose (as the outlet on the unit is 100mm). I've got this connect to a floor scoop, and other outlets with blast gates. I've always been happy with the suction considering it's only an entry level unit but I was looking to upgrade this to something with a bit more power. It's mainly dust I deal with (sanding, mitre saw, I do do some turning but not alot and routing) so am I right in thinking that I do want a HPLV unit like I already have?
One thing that's recently struck me is, am I using too large hose? Because this is a HPLV unit, would I be better using 63mm hose instead of the 100mm? Would this give me better suction? Or, because the outlet is 100mm from the unit, can i just reduce the hose to 63mm at the end where it connects to the tool and it would be similar to using a 100mm to 63mm converter from the unit and running 63mm pipe all the way.
Sorry i know that's a bit of a mouth full but hopefully it makes sense!
Thanks in advance.
Thanks in advance.
