I want to get in a proper extraction system. The way I see it it is only the P/T that really really needs the chip extractor - nearly everything else can be sucked away by a wet and dry vac - ie router, table saw, RAS, sander, morticer etc.
I'm thinking of getting this http://www.axminster.co.uk/axminster-63 ... prod21901/ asit is a fair bit cheaper than the 100mm setup. And maybe just physically bringing the extractor to the p/t each time there is work on.
What you reckon or should I go for the bigger 100mm set?
