Dust extraction - 63mm / 2.5" Using Camvc
Tugalis
7 Feb 2015
Cambridge
Hi,
Bit of a Noddy question so bear with me....
I recently bought a camvac which I extremely happy with. I went for the 2.5" outlet as it was a little cheaper and in stock which is quite a feat for a camvac it seems. It took ages to find a supplier in stock but they were great with helping me!!
I've been using 100mm extractors in the past as accessories and connectors are easily availabile. This seems to be a little more difficult with the 63mm /2.5" pipe.
Question - Does anyone know where I can find a reducer from the 63mm/2.5" to a 38mm pipe? I have picked up 5m of 38mm pipe for use hoovering up the workshop but I'm a little confused how the adapters work and the sizes stated. What I would really like is a reducer where the 2.5" pipe screws into it and then the 38mm slides over the top of the reduced section if that makes sense.
Also, is there an adapter where I screw the 2.5" pipe into one end and then you can slide an additional 2.5" pipe over the other end. What I want to be able to do is run a pipe from the vac to a dust collector then to a point a my workshop where all of the hoses from other machines will meet it. That way I can just attach whichever machine I am using. The work shop is only small so I think this will be the easiest option as I don't need to run 2 machines at once
Hope that has made sense, any help is greatly appreciated.
Thanks,
Josh
Have a look at these Josh.
http://www.ebay.co.uk/itm/SILICONE-REDU ... ?var=&hash
http://www.ebay.co.uk/itm/like/20098138 ... 386&adtype
http://www.rutlands.co.uk/pp+woodworkin ... ors+d01103
If no exact fit you could buy one closest to yours and manufacture a reducer from rainwater or plumbers waste pipe.
http://www.screwfix.com/p/solvent-weld- ... 104255#_=p
Buy the pipe slightly over size in the inside dia then slice a piece out it lenghtways until you can squeeze it tight over the desired outlet. Apply some solvent weld contact cement http://www.screwfix.com/p/floplast-sc25 ... -_-Product Listing Ads-_-Sales Tracking-_-sales tracking
to the cut joint (not the outlet or you wont get it off) and hold its closed tight with jubilee clips
http://www.screwfix.com/p/blue-zinc-pla ... f-10/40251
A friction fit is what you are after so it stays put on the machine but comes off when you need to remove the hose.
Good luck
David
Hi David,
Just what I needed. Thanks for that. Very much appreciated!!!
I will give those a go and let you know how I get on.
Josj
