SpoonsbySven
Hi Folks,
I'm considering buying a Meddings pillar drill. I'm trying to work out how the height adjustment on this model works. The pillar drills I've used have had a table that moves up and down the column (usually by means of a rack and pinion gear).
However, this one does not have a second table. There is a "collar" on the column between the base and the motor, and it appears to have a handle on it, so might have something to do with height adjustment, but I can't quite see how it would work. It doesn't look like a second table should be attached there.
The column extends through the top of the belt housing, and so I assume that maybe the whole motor etc could move up and down, but it's not all that clear from the photo:
Is anyone familiar with this style, and any advantages/disadvantages?
Very grateful, as always, for any advice...
Cheers,
Sven
Cheers,
Sven
