dlowry_uk
Hi,
I'm building a small lean-to to hide our 45kg gas tanks. Just need some advice on door construction. I'm hoping to use it as a learning exercise for frame-and-panel construction.
The opening is 140h x 80w, with a double door, so 2 long narrow doors (140 x 40). The plan is to biscuit-joint the frame from 32 x 100 stock pine, with an additional horizontal rail at about 1/3 height, and rebate the back for 12mm ply panels.
So, a few questions:
1. Is biscuit-jointing with PVA ok for outdoors?
2. Is the frame likely to sag without diagonal braces?
3. Should i take the easy route and simply pin a face-frame to full-size ply panels and avoid all the hassle?
Drew
Drew
