Hi guys
I dry assembled this chair so I could measure up for leg stretchers.
Dunno what happened when I was taking it apart (probably not carefully enough) but it went crack!! (homer)
You can see crack in this photo. Its on the front leg just above the front rail mortise. Its about 20mm long
Please someone tell me, "Everything's gonna be fine, you don't need to make another leg. You just need to do this......... and it will be even stronger than before!!"
What options are there for repairing it and which will be strongest.
How do I get the glue into the crack??
Best regards, Andrew
