Mister S
I have a door frame in a stud wall where both sides and the top have warped in two directions (and also the stud wall I assume). The door is a modern replacement which is flat and true, so there are unsightly gaps (of varying thickness) visible at the sides and top. I was thinking of fitting a straight edge to the frame, trimming back the curved parts until they are uniformly flat and then replacing the cut away part with a strip of wood to bring it all back reasonably true so the door fits flush again.
I was thinking of just paring back with a sharp chisel. As this won't give a properly flat surface I won't be able to use PVA, so I wondered about Hard As Nails or similar, sanding any squeeze out flush and then finally painting everything.
The question is, will the hard as nails crack over time? Being a doorframe, there will be a fair bit of vibration every time the door is closed. Cracking along the join line would be in plain view.
I've used this kind of stuff before, but only in applications where it's out of sight.
Anyone got any experience of this?
Steve
Steve
