I've used a Metabo one for years mostly when finishing 'furniture' for shop fits. Much of this is veneered MDF and I can use the 5mm orbit on commercial veneered boards (veneer is only .6mm thick) so not really that aggresive. In that case I would start with the 5mm orbit P150 disc to get the veneer smooth and then go over with the P150 on the 3mm orbit and then continue sanding further grits on 3mm orbit. Can only remember going through a veneer once in the middle of a board, although you have to be careful on the edges.
I have recently purchased a Festool ETS150 3mm orbit and this a different machine entirely, well same machine but a huge difference in quality of build and end results are better. My Metabo feels very rough in comparison to the ETS. I bought one when a rep let me try one for sanding spray painted MDF. (He used to be self employed as a sprayer and it was his machine he had used for many years and it still felt great) The Metabo is just too unbalanced to run well and it just sands through the paint. The ETS is a dream and has saved us a lot of time in finishing flat panels. It also sands quicker than the Metabo on 3mm orbit. The only thing I use the Metabo for now is when I need the 5mm orbit for faster material removal. I will eventually get a 5mm ETS as the difference is so great.
While deciding on whether to get the Festool or not, as I live near the Festool importer, I dropped in to try the machines out. I tried out the Rotex as well. The Rotex is not, in my opinion, a machine for fine sanding. It is really made for removing material fast and polishing. The ETS is very smooth to use and is the finish sander in their line up. The rotex is much harder to hold, more like an angle grinder, and doesn't feel very 'smooth' in use, it feels in some ways like the Metabo does and this is prob 10 years old. The ETS is a one hand machine
From what you say you are looking for a finishing sander, go for the ETS not the Rotex and the Festool is worth the extra cash over the Metabo.
For you do decide to get the Rotex then don't get a 125mm one, or at least try it before you do. It felt all the time like it was fighting against me. Even the guys at Tool Technics (importer) don't seem to like it!!
It's only my opinion but I hope this helps.
Johnny B
