Not if you've been bending it to draw curves!!Beau":1p0gpypz said:Sure one can get by without but they are so useful. As you say for checking and aligning surfaces but also good for cutting veneers and they can be carefully bent to draw curves. Trying to check flatness of a surface with a level that has 20-25mm wide base is so much harder than the fine edge you get on a good straightedge.
If it's the slightest bit bendy then it won't be reliable on edge.Beau":23gryt2q said:Jacob it's easy to hold a thin straightedge on it's edge for a reference. ........
Jacob":16qutaf1 said:If it's the slightest bit bendy then it won't be reliable on edge.Beau":16qutaf1 said:Jacob it's easy to hold a thin straightedge on it's edge for a reference. ........
If there is a bend in it then it could lie flat on a curved surface so unless you can hold it dead straight it is unreliable. The usual thing with a bendy straight edge is to tilt it one way and the other to get best fit, which just isn't going to be as reliable as a dead rigid edge.Beau":2no6xui3 said:Jacob":2no6xui3 said:If it's the slightest bit bendy then it won't be reliable on edge.Beau":2no6xui3 said:Jacob it's easy to hold a thin straightedge on it's edge for a reference. ........
It is and your wrong
It's not this flexi though http://www.dmmiller.co.uk/pajarito-no21 ... -edge.html
Not as cheap as just planing up an off-cut.Racers":h9hzc8m8 said:A length of ground flat stock makes a good straight edge for woodworking, and is cheap.
Beau":1ojs13r1 said:Jacob":1ojs13r1 said:If it's the slightest bit bendy then it won't be reliable on edge.Beau":1ojs13r1 said:Jacob it's easy to hold a thin straightedge on it's edge for a reference. ........
Jacob":3m8tj18b said:What you do is cant the spirit level on edge.
