Diy shed advise
Simurgh
New member
12 Oct 2017
Cumbria
Hello, I will start out by saying I have rad several posts but have not got through all 266 pages yet. I apologize if this has been asked and I haven't seen it yet.
Having said that the posts I have read have helped me with many aspects of planning my shed.
I will highlight the question if you want to skip the next bit
My situation is I am completely new to woodworking, I have only made two projects; a computer desk and a stair safety gate. I have loads of ideas but have no where to make things. I am very limited on space and to complete my desk I had to commandeer the dining table for a few days. I have done multiple plans for a shed but it is going to be a a long while to afford it. Also I can not justify spending so much with out actual making things.
I had put the idea on hold until I was looking at some pallets I have already dismantled. the pieces on hand are 33mm x 85mm by approx 1.5m
So here lies the question(s)
Could I use the supporting beams of the pallets to form the frame of the shed? Either putting them in a square pattern and then bolting them together to get the height or have two pieces on top of each other and then bolt them to a piece next to them e.g
file.php
The size I am looking at is 4M by 3M probably about 3M high.
The aim is obviously water tightness and for as cheap as possible. Insulation can come later, as well as a better shed once I can justify spending money on it.
The attached shed plan is a design I put together on Sketchup, Having read https://www.ukworkshop.co.uk/forums/small-workshop-wip-t104750-15.html I realized I hadn't planned the cladding correctly and it clearly isn't finished.
Not sure if this is enough info or just too much waffle, So if I haven't given enough just ask and I thank you in advance for any advise offered.
    33.4 KB
    226.9 KB
    94.3 KB
No. The timber isn't good enough, and it isn't big enough to be reliably strong enough with a join. Besides, the frame isn't the expensive part of a shed, so any savings would be small. Wait until you can do it properly. Try Freecycle for some better materials, perhaps.
I posted a reply the day after you replied but it hasn't showed up.
Thank you for replying, I had a feeling that would be the answer. I think I was just wishful thinking
