russ_1380
Hi guys, Another question.......
I have done some research and basically found that DIY sandblasting is pretty useless, due to the huge CFM requirement needed for large areas.
However, I'm looking at perhaps getting a sandblaster to clean up old steel hand tools and small parts off cars on the bench/cupboard. It is only for hobby use, so wouldn't be used every day.
I would only need to blast small areas, not large scale sandstone cleaning or blasting whole car bodyshells.
My question is; if I bought a largish (for DIY) compressor say one with 19cfm, would this be sufficient coupled with a cheap hand held balster?
I appreciate it would be air greedy and my compressor tank would run empty pretty quick, requiring it to recharge itself often. Is this do able for small areas though? Or is it likely the compressor would be running all the time to keep up?
Has anyone had experience of this?
I don't really want to hire one if at all posible
Russ
Russ
