adidat":khr8nm23 said:we used to turn the felder ones into marking knives, and they made excellent scrapers
but thats about it
adidat
custard":15ff2r7k said:It's the Felder ones I'm talking about, according to the latest price list it's getting on for £20 for a knife change!
Lord Kitchener":1plsv7sg said:custard":1plsv7sg said:It's the Felder ones I'm talking about, according to the latest price list it's getting on for £20 for a knife change!
I daresay I have a different point of view about this to you, because I think if I could do a straightforward knife change in a planer for £20 I would be well happy. In fact, hearing that it's only £20, I must look into getting a Felder planer. Which model do you have?
Lord Kitchener":67s76hj3 said:I daresay I have a different point of view about this to you, because I think if I could do a straightforward knife change in a planer for £20 I would be well happy. In fact, hearing that it's only £20, I must look into getting a Felder planer. Which model do you have?
ProShop":3ptlhm3k said:Lord Kitchener":3ptlhm3k said:I daresay I have a different point of view about this to you, because I think if I could do a straightforward knife change in a planer for £20 I would be well happy. In fact, hearing that it's only £20, I must look into getting a Felder planer. Which model do you have?
An AD410 will set you back over £55 for a knife change on a 4 head or over £41 for a 3 head.
Lord Kitchener":37nr1qaq said:ProShop":37nr1qaq said:Lord Kitchener":37nr1qaq said:I daresay I have a different point of view about this to you, because I think if I could do a straightforward knife change in a planer for £20 I would be well happy. In fact, hearing that it's only £20, I must look into getting a Felder planer. Which model do you have?
One would expect a 410mm planer to be more expensive in the knife department. Upside of that is that you don't need to change them so often, if soem care is taken is spreading the workload.
Lord Kitchener":2mnjngqd said:custard":2mnjngqd said:It's the Felder ones I'm talking about, according to the latest price list it's getting on for £20 for a knife change!
custard":21j54rba said:Lord Kitchener":21j54rba said:custard":21j54rba said:It's the Felder ones I'm talking about, according to the latest price list it's getting on for £20 for a knife change!
Felder CF741, four knife 410mm Felder planer system.
The regular HSS knives cost £51.12 including VAT for six (each has two edges), so a knife change costs £17.04.
The super duper M42 knives would mean £34.48 to change knives.
custard":3qhsxjl6 said:Felder CF741, four knife 410mm Felder planer system.
newt":3qhsxjl6 said:So it is low cost to change blades on this machine, lucky you.
ProShop":n98o8xrc said:custard":n98o8xrc said:Felder CF741, four knife 410mm Felder planer system.
Methinks you've got your sums wrong, as in my prev post to change a 410 in M42 comes out at over £57 + VAT = over £68. + delivery
newt":n98o8xrc said:So it is low cost to change blades on this machine, lucky you.
Not so Lucky, especially when you have to change them after a weeks use.............................regularly
newt":16q284x5 said:ProShop":16q284x5 said:custard":16q284x5 said:Felder CF741, four knife 410mm Felder planer system.
newt":16q284x5 said:So it is low cost to change blades on this machine, lucky you.
Is that due to the through put of wood or the type of wood, you are changing the blades every weekif this is just for hobby work then, I amazed, if it is for payed work recover the cost from the customer.
Register today and take advantage of membership benefits.
