Hi, I've just tried to change the discs on my old Axminster 10inch disc/belt sander. Yesterday I cleaned off all the old glue and paper and cleaned of the disc with some thinners. Today I tried to apply a new self adhesive disc (from Axminster Tools) and I've just tried three in a row with no joy. The glue is not sticky on the outer edges and just lifts off the disc. The centres are fine but no way will they stick properly. What are other using out there and do you use a spray or contact adhesive as well? Should the discs that are "self adhesive" work?
