jimi43
I am slowly going through my workshop tidying things and cleaning power tools and setting them up ready for a project and I am now up to my trusty DW739
I have a couple of questions if someone can assist I would be grateful.
Firstly the top wheel and tensioner assembly has always for me been a weak point of this saw. I took the tensioner assembly apart to try to see if it could be set better and the washer, bearing (thin), washer, spring assembly fell apart and dropped on the floor.
Looking at the parts list I think I know how it goes back together...basically the thin bearing goes between the two flat washers at the bottom of the plastic knob around the tensioner shaft and above the spring...am I right?
Secondly there is some crud and wear on the rubber/plastic wheel tyres and I thought these could be tidied up or replaced but it looks like you have to buy new wheels COMPLETE! Is this true? At a total of £140 for the wheels I might as well get a new saw!!! Can something been done or should I just leave them as they are...they doesn't seem to be drive problem!
Thirdly I feel that the flat bevel blade guides have always been a poor second to bearing guides seen on other saws. Can this be modified?
and lastly...are there any aftermarket fences that can be recommended for this model at the fence could do with changing. I am fed up with lining the thing up square!
Any other tips from other owners on tuning this (otherwise great) saw would be most appreciated.
Jim
Jim
