RogerS
Say you're making this
out of solid timber...but you can't get timber wide enough to make the side panels in one (not that you'd really want to, you understand). In fact you can't get timber wide enough to make it out of two panels jointed together, you need three. So what would you do (assuming that the variation in figuring and colour is quite high).......
a) make the side panel out of three equal width pieces
b) make the panel out of two pieces as wide as you can then add a smaller third piece to make up the width..and if you went down this route, where would you put the thinner piece ...between the two wider pieces (ie in the middle) or towards the front or the back
c) any other suggestion
