Hello,
So here goes with the story so far...
Heres the pile of oak I started with. All air dried with some 2 inch and 1inch planks all from the same tree. All sourced from here, which is abouit half hour drive from me. I like the idea using the wood sourced from local forests. These fellas own a small woodland, but also get wood from surrounding estates.
As I've mentioned in some other posts... forgot to turn the radiator off when I brought it indoors... Nice Split! ](*,) This was generally only on the 2" stock so I have managed to work around most of them. It stayed in doors for around 3 months so it was reasonably stable when I started hacking into it.
So after alot of work with some hand planes I managed to create alot of saw dust and these. Not all the pieces I need but most of the stuff for the frame.
This next pic shows the top glued up. Made from 3 planks just butt jointed... no biscuits or owt.
Some action shots.... just noticed that all the pics so far have been inside and not in the shed. Using the shooting board to square off the ends of the legs.
Also managed to get all the mortices into the tops of the legs. Not done these before and was lucky enough to have watched DC's latest DVD before tackling them, which has helped alot. All chopped out by hand with that second hand pigsticker you can see in the pic.
So thats about it so far. Its been slow work and have not had many full weekends at it. I'm also getting married in two weeks and SWMBO has banished me from the shed. Apparently I always end up cutting meself when I'm in the shed and she doesn't want any cuts and grazes in the pictures :roll:
Anyway, I have a couple of extra weekends before the next submission so should be able to post more then.
Darren
Darren
