Danish Oil
sparkus88
18 Sep 2009
bristol
Does wood get much darker after the 1st coat with each coat of plain danish oil? I am applying it to a pine desk but unsure how many coats I'm going to need, therefore unsure how much oil I need.
thanks
Mark
Well normally I use 3 coats for inside work but I have never used it with softwood/pine. Keep applying coats until you notice that its not soaking in anymore and then make that your last. How danish reacts on pine in terms of colour I can't help sorry.
I dont find that it changes colour after the first coat. I usually apply two thickish coats with a cloth then give it a light sanding then put on a much thinner top coat.
Never used the stuff for the reason of the name. I do use rustins Danish Oil.
Now this plastic stuff, does it bring out the same colour and "natural" protection and is it food safe?. I say natural as danish oil although it is a mix and factory made, the base is linseed oil which is a natural product. I have always favored danish oil over other finishes on oak due to the way it makes oak look and don't leave a plastic'y coating like many other finishes. Ill be happy to try this rustins plastic one though.
If you wish to try it, don't use oak first off - use a piece of maple, beech, sycamore or something close grained. Experiment with the final finish on a smooth surface first - if you want a matt it'll look a bit odd on oak, because it'll show glossy freckles. You can choose between a flat finish, or virtually a french polish - if you over polish, you can flatten it back. On some woods the first coats take an age to dry, but subsequent coats are fine. Don't be tempted to use too many coats too quickly, no matter how dry it feels - I tried six coats in 24 hours, and had problems - the surface feels dry, but the solvents underneath get trapped. It's often worth using throwaway brushes.
Now then it seems very much that Danish Oil is th better choose for Oak still and if the first coat takes to long to dry then again it seems Danish Oil is the better choose for me that needs to get products out ASAP.
Does this plastic stuff yellow b/white matt emulsion paint?
Yes, Roger, we are. On some tropical hardwoods the first coat can take two or three hours to cure fully - after that it's minutes. I can't tell you which ones - they weren't identified. It's no big deal, but it slows you down when you're used to the stuff being touch dry so quickly.
Is Danish Oil foodsafe? ie on chopping boards and worktops?
I have been looking for a supply of mineral oil to no avail, journeys to local suppliers have all drawn blank looks... I finished up getting a 1 Litre tin of Rustins worktop oil with the silver microbial additives but needed a liver transplant after handing over the £28.00... I have many tins of Danish oil in my workshop but thought it may not be the best for the many chopping boards we have around our kitchen.
cheers
Les
