Hiya
A key reason for not using a Stacked Dado blade are that the types of cuts done with them are nearly always just as easy (and certainly safer from a guarding point of view) done with a router and guide. Having said that a stacked dado blade is much faster than a router.
The main scary bit for me is there is a hell of a lot of energy stored up in the spinning mass of blades if you do get kickback or heaven forbid slip onto the blade, the damage would be horrific. Guarding the blade correctly is possible but tricky. Searches will pull out suggestions from many contributors but the posts from Scrit are well worth your time reading.
At the end of the day, you are responsible for your own decisions and actions. I have a stacked dado blade set and treat it with respect, I guard as best I can, use push sticks and make sure I am standing completely balanced when using the table saw.
The best thing about advice is you don't need to take it, but I highly recommend you take the comments in previous posts at face value and make your own decision as to use dado's.
HTH
