parting off tool. clue is in the name. wrong tool for the job.
A square ground parting tool can be used for all sorts of jobs, not just parting off.
What's the advantage of leaving the middle bit till last ?
Cheers Andy
You can turn brass with a negative rake HSS form tool, 350rpm is too slow 1000 rpm minimum.
1.5mm is half the rod diameter. I'd mount it as close to the chuck as I can, put a steady on the other end ((just a roller for it to settle on), I wouldn't put that end on a centre as your putting force on the rod that will make it want to bow, hence the break.
I'd grind a grooving profile at 2mm and take 3 cuts overlapping. worst bit will be the first cut.
I thought it was a sort of keyway, so started putting a solution to mill the slot by putting the cutter in a collet and clamping the rod on the cross slide but the description sounds like a sort of partial parting off if I understand the description correctly
Register today and take advantage of membership benefits.
