Hudson Carpentry
Anybody know of any key type cabinet locks thats compatible with push to open catches? Padlocks not suitable.
DeanN":1awele6e said:I can see you'd have the same problem with any cabinet lock that uses a keep, as the keep is usually only wide enough to accept the bolt with minimal movement. An option may be to not use the keep, and instead have the bolt secure itself behind the frame (reinforced with a metal strip). Similar approach is taken with mailboxes where the bolt or tail rotates behind a lip to secure it.
