Good day
I would like to share with you my method.
First, check the alignment of the blade to the miter slots.
The idea is very simple, I make part of the sled, cut the kerf and refer to it as a reference point (or line) to position the "Back Fence" square to the kerf by "locking" everything together.
I discovered that the plastic drawing triangles are very, very accurate, and I use them to locate the fence (actually, as you will see, I'm using the shop-made triangles that were "copied" from the plastic one).
By cutting the Runners 1 mm narrower than the miter slot width, it's very easy and fast to cut the runners and, I think, will eliminate any binding due to expansion with humidity changes.
My table saw is different and has only one miter slot, so I made some kind of "fiction" miter slots for the guys with the "normal" table saw...(I think everybody except me)
It took me around 1½ hours to make it (including 148 pics), so I assume that it should take you 2~2½ hours, considering that you have to prepare the parts (I used scraps from around the garage).
niki
niki
Code:
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/01.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/02.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/03.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/04.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/05.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/06.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/07.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/08.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/09.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/10.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/11.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/12.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/13.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/14.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/15.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/16.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/17.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/18.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/19.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/20.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/21.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/22.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/23.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/24.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/25.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/26.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/27.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/28.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/29.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/30.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/31.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/32.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/33.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/34.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/35.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/36.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/37.jpg[/img]
[img]http://i208.photobucket.com/albums/bb151/matsukawa/Crosscut%20sled/38.jpg[/img]
