Mikey R
Hi everyone,
Im sure this question has been covered many times here over the years, but a quick search didnt bring anything up.
I was always taught that you joint with a plane that is long enough for the board you are working on.
So I was chatting with a guy called Jon last night, a professional electric guitar builder, and we got onto the subject of jointing laminates of maple (~22mm) and dense exotics (~6mm) to make a guitar neck.
Anyway, Jon says that he uses machines to joint his neck laminates - which is fair enough, he needs to make a living and hand tools would be slow for this. But then he says that he uses a drum sander for the 6mm laminates.
He says that using sandpaper creates a better surface for gluing than a planer, as the tiny scratches increases the glue area, allows the glue to sink further into the wood and makes a surface similar to a 2d finger joint.
Now, this goes against everything Ive ever been taught - you joint with a hand plane and NEVER with sandpaper on a sanding caul. EVER. But Jon is an increadibly accomplished craftsman and makes truely amazing instruments with invisible glue lines.
So, the first question is, whats the modern wisdom when it comes to preparing a glue surface for both strength and appearance. The second is, does it matter?
