Err....yerr, I reckon you are right, UpstartThread97; my moustashe.
Coincidentally, I was researching a "Coronet lathe" only to discover there were three dynasties of them. As you may know, there are older ones, purpley-red, tubular bed, that I think have the narrower sander you may be asking about?
This pikky nicked from Lathes.co.uk, all rights to that site.
Then, there seems to be a slightly more recent reincarnation, some painted blueish, that have a
wider sander?
Ditto from Lathes.co.uk.
These were marketed separately as "Whipittoff" and look totally different to the ones I suspect you are asking about.
Then, thirdly, Record stepped in and used the name for some of their - structurally quite different - CL range. No sander for them so far as I know.
Anoracks? Please feel free to correct my superficial research, I haven't time to trawl cyberspace presently.
UpstartThread97, if you don't mind, and if you have the time when you meet your guru, could you please ask him what rpm the Whipittoff should be run at? And, does he have a source of belts for them? I've been making my own with variable results
and would like to improve things.
Thank you, Sam
