Hi.
I've managed to buy this bit of vintage british engineering. It was a little costly to send it to Portugal but I think it was worthy since it is in very good condition for its age. It's a Cooksley BPJ planer/thicknesser and it has very small footprint for its capacity (12"x9").
The tables are just shy of 120cm and since the fence slides on a front rail it doesn't take as much space as the traditional fences with a long metal bar in the back.
Anyway I have a couple of questions about it now that I'm preparing to clean it and bring it back to work.
First I'd like to know what kind of knobs/handles would fit in the surfacing table screws. Here's a pic:
So there's a shaft (5/8" diam) with a roll pin, but the knob is missing. I thing the knob was a removable one, since it would stand in the way of thicknessing otherwise. I can of course improvise a way to turn that shaft, but does anyone know where I could source a replacement?
Other question is about electrics. This is a 3phase machine I only have 1-phase in my garage. The main motor is dual-voltage so I can run it from an inverter but the feed motor is single voltage (400V) and dual speed. The motor plate says it can output 370 W or 180 W depending on the speed. Would I damage the motor if I also feed it through the inverter at 240V 3ph? Theoretically the motor would output 370/sqrt(3)=213 W if I run it at the highest speed. Is that ok?
many thanks.
many thanks.
