A
Anonymous
Guest
Hi all
It's Bean's fault really.
He was expressing love and admiratione for my bandsaw (well, he said he liked it) and asked if there were any problems.
Well, yes, the resaw height is ONLY 6" which is annoying :evil: says I.
Two engineers faced with a problem!!! After a brief discussion and a bit of measuring, work started and now my bandsaw will resaw a FULL 9" depth!!!!
I originally thought that I might have to reinforce the section around the aluminium extrusion (already decided how) that holds the bearings but this has proved not to be the case as the sheet steel that the case is made from is quite thick and the door locks tight providing additional support. The defection in the ali extrusion when I push against it by hand is the same afer the mod as it was before
Bandsaw is Charnwood W720 155mm. Standard chinese job which is sold under many brand names
Here's what I did
Before (note ruler at 155mm depth of cut)
I removed the blade and top wheel first. Now I modified the aluminium section that holds the blade guides first by shortening it slightly and cutting a little shoulder at the top. Also had to remove some material from the slot (see picture where wheel runs through ali) to allow the top wheel to run through the ali.
Next, I got the angle grinder out and cut a profile in the rear to accept the bearing assembly when fully raised
I also made a small cutout in the side and redrilled the holes to mount the internal channel that guides the ali extrusion when lowering and raising the bearings. Also re-drilled the clamp bolt hole a little higher and slightly modified the steel that sits at the other end of the bolt by cutting 12mm from the bottom of it
I had to file a coutersink along the slot that originally held the caphead bolts that secured the bearing guides to the end of the extrusion. I fitted 6mm countersunk bolts in it.
Here you can see the 9" depth of cut and I have placed the same ruler from the first picture in shot too for reference
First resaw operation was 7 1/2" Beech. Lovely
OK. Pretty easy and the result is 50% more depth of cut. Used a hacksaw, angle grinder and file + battery drill.
Total time for the job was 4 hours.
Here's what I did
