Just moved in recently, and as you can see the conservatory needs some TLC!
No problem replacing the beading, however do you use sealant behind the beading to stop water ingress?
The horizontal piece you can see on the photos, how will that be fixed into the timber, or should I just cut straight though and splice in a new piece. What is the easiest way to cut it out without making amess of the surrounding woodwork?
Also how would this affect it structurally.
Hope you can help.
Dean
Hope you can help.
Dean
