harris
A friend has disconnected a NVR switch on a power saw without noting where the spade connectors were joined. The none starting problem has been diagnosed as a faulty start capacitor and the switch has to be re connected. The only marking on the switch is on the back of the casing and is "IN" close to the two spades behind the ON button and "OUT" close to the two spades behind the OFF button.
The switch output is obviously then to go to the capacitor. Can anyone provide an easy to follow wiring diagram for a novice to follow in order to reinstate the switch. There is no information as to the manufacturer of the switch.
