Hi
I know this has been flogged to death on this forum, I know because I must have read every post so apoligise if your repeating yourself.
Started off looking to build a simple shaker style wardrobe for my grandaughters bedroom easy enough a box with 2 doors.
Build a frame 3/4 x 3" oak put a 1/4" groove in it and slide in 1/4" oak veneered mdf and glue up. do this for 2 side panels and the doors. Rout a 1/4" slot for the back panel. Use 18mm oak veneered mfd for top,bottom and shelf. Edge this with the iron on oak edging.
The problem arose when I started going through the past posts to see if I was on right track and what really impressed me was the painted mrmdf the quality of work is superb so next step go for painted mdf as it has a softer looking finish for a girls room were the oak might be to old looking.
So I am back to where I started a simple box with 2 doors but the qustions now are.
Do I use 22mm or 18mm mrmdf for sides, top, bottom and shelf.
Do I use18mm with 6mm panel for doors or go bigger.
Can I use european hinges to hold doors.
What is the best method for jointing mdf my prefered method is dowell and glue is this strong enough.
If I look at past posts I could find numerous different answers to above and each of them a valid solution from peoples personal preferences and experience, an example would be an mdf shaker doors some make stiles and rails as normal some people glue strip to front only and somepeople glue strips to both sides.
I know these are basic questions for you but they are not for me so your patience is appreciated.
Terry
Terry
