Hi folks
I have made tentative steps towards getting this big old compressor up and running
The tank is 1800 long by 500 dia- my calcuations make that a 350 litre tank.
So, it needs new belts - one is missing, the others are pretty knackered
Opened the drain valve and drained the water off - not much in there
Check out the manufacture date!
Having fired it up the pressure on the "regulator" began to climb.
However, there is no automatic shut off! So the pressure carried on climbing. Once it got to 120psi, I manually turned off the power. A little further investigation, and I took this part off (behind the gauge in the shot above)
And dismantled
So, the semi ball at the bottom of the fitting would be pushed up as the pressure rises in the receiver. By adjusting the top section of the "regulator", this ball can be made to slide past the two holes in the outer casing, thereby allowing a sort of relief and reducing the pressure in the tank. I think......
But the problem with that is that the compressor would have to be left running permanently - does that sound right???? It isn't too much of an issue if it is as the compressor is situated outside, and will be used solely for spraying and can easily be switched off as necessary.
Any input/thoughts appreciated.
Karl
And dismantled
Karl
