Random Orbital Bob":yxwwrbgh said:
Ah....got you.....of course...they're expecting dowel stock aren't they (or in fact metal rod originally).
My 11mm stock is rough as old boots...the reject fingerboards are bandsawn on some kind of animal given the teeth marks. I then saw them into square pegs. They're only 11mm because that's the typical thickness of the fingerboards. I generally mount them into either a Jacobs chuck morse taper'd into the headstock or if I can be bothered a spare chuck with pin jaws. Both have their problems: The Jacobs chuck has the perennial risk of wobbling loose and the pin jaws are of course in a monster chuck that my knuckles are too close to for my taste........hence the interest in the collet chucks.
It's becoming clear to me they're expecting tightly controlled dimensions going in and as I now realise, round stock too.
Two cross post whilst I was typing my epistle
Close tolerance not at all necessary.
I often use 'square' ie. rough sawn and questionable - stock and there is seldom an issue. 'Twisted' stock can be a problem and tail-stock support in the initial stages can be beneficial.
Once you have the square stock mounted you can very easily turn 10mm of the outlying end to round, remove the piece, change the collet and mount gripping on the freshly turned - now round - section - it takes all of 20 seconds
