Good Morning All…
I have a question with regards to a coffee table I was planning to make. I have a fairly large piece of sycamore which I was hoping to use for the top. I also have a lovely piece of rose wood which I was hoping to use as a centre section of the table. So plan would be to split the sycamore and flatten and thickness it. Then have a centre section of the rosewood to joint the two pieces of sycamore. Legs/rails etc. would then also be rosewood.
Does anyone see any problems with splitting the sycamore down the centre and inserting a centre section of rosewood the same thickness for the entire length of the coffee table. Plan would be to joint the rosewood to the sycamore using biscuit joints and glue?
Thanks in advance for any tips/advice.
Ben
Ben
