paul24dual
Hi everyone, my next purchase will be either a
Circular Saw or Mitre Saw for furniture making (OR Both)!?
Can you advise?
Can you advise?
I have to agree. The multifunction table ( MFT ) of which the above is a version is brilliant but the cuts will only ever be as accurate as the positioning of the holes and getting them accurate enough in a DIY version is a daunting task.rdesign":1tme4k5d said:festool ts55 with qwas dogs will do everything for u. accurately drill holes in a mdc sheet 20mm holes in a square grid pattern plenty of vids show how to use the saw with the dogs gives u repeatability accuracy and speed. for cheaper than a good table saw. and its portable.
mark aspin":1hbkoa1n said:Looking through the the chap's posts, he's just starting out and has a limited budget. I don't think suggesting over £1000 of Festool gear is very helpful considering!
Maybe our first questions should be: "what is he planning to make?" and "how much does he want to spend?"
A hand-held circular saw can produce accurate cross cuts when used in conjunction with a simple jig. This could be all he needs for the time being.
Hope this helps!
