I have just bought the cole jaws from Steve on the forum. What would be the cheapest chuck to buy to have them set up rather than having to keep taking the jaws off my supernova every time.
Cheers in advance
Elaine
Cheers in advance
Elaine
Elaine":241jmj3d said:I have just bought the cole jaws from Steve on the forum. What would be the cheapest chuck to buy to have them set up rather than having to keep taking the jaws off my supernova every time.
Cheers in advance
Elaine
Vic Perrin":2zjdqjj6 said:You can leave the cole jaws attached with the use of longer cap screws you can mount any of the jaws you have on the front of the cole jaws. I do not like using them in this manner and prefer to change over as required for the few minutes it takes.
Spindle":2lnzmv78 said:Vic Perrin":2lnzmv78 said:You can leave the cole jaws attached with the use of longer cap screws you can mount any of the jaws you have on the front of the cole jaws. I do not like using them in this manner and prefer to change over as required for the few minutes it takes.
Hi
Unless you have a version of Cole jaws that I'm unfamiliar with I wouldn't recommend this practice. The jaw security is dependant on the registers, (the arc shaped machinings on the back of the jaws), engaging in their matched recess in the chuck jaws. There are no registers on the front of any Cole jaws that I have seen therefore the jaws will not seat correctly and the screws will be under shear / bending loads rather than their designed tensile load.
Regards Mick
Spindle":28gam2xi said:Vic Perrin":28gam2xi said:You can leave the cole jaws attached with the use of longer cap screws you can mount any of the jaws you have on the front of the cole jaws. I do not like using them in this manner and prefer to change over as required for the few minutes it takes.
Hi
Regards Mick
bellringer":mpxi7sa6 said:Spindle":mpxi7sa6 said:Vic Perrin":mpxi7sa6 said:You can leave the cole jaws attached with the use of longer cap screws you can mount any of the jaws you have on the front of the cole jaws. I do not like using them in this manner and prefer to change over as required for the few minutes it takes.
Hi
Regards Mick
All the cole jaws i have seen have them and the nova one have them for sure
Hi Elaine, Exactly my feeling with regard to swapping the jaws when you need to. I tried my cole jaws with a set of 2" jaws attached to the front and although it all worked fine,I was frightened to death about catching my knuckles on the flying cole jaws. I just chill out now and swap the jaws when need be.Elaine":7aye19zc said:Uhm :roll: as usual great feedback. Always leaves me pondering which is good. I don't want to be rapping my knuckles. So either, have patience and swap the jaws over when I need to or buy a chuck. The piggy bank is looking quite slim after the festive period. Patience it is then. But I shall start putting the pennies away.
In the meantime I shall have fun researching your suggestions.
Elaine
Spindle":32zq3wj4 said:However they are the only jaws I know to do this - the Robert Sorby jaws in Steveuk's photo, (the ones the OP purchased), don't nor do my two sets of Vicmac ones.
