Chestnut Shallac Sanding Sealer
Waka
8 Mar 2004
Weymouth
nearly coming to the end of a project in AWO, and I intend to to use the above sanding sealer. Question is, how many coats should I put on before I go to the wax.
Hi Waka
You should only need one coat of Sanding Sealer; so long as you're only applying wax over the top of it you can put a second one on if you really feel the urge, but the first coat will do the work!
Hope this helps
Terry
