Chessboard
Jismacgregor
4 Aug 2017
Cumbria
Hi,
I am going to make a chessboard but would like to ask the experts some advice first. It would seem that there are three methods of making the chessboard:
1) Veneer on man-made board. I can see that this is probably the best solution and will avoid movement of the wood being a problem. But how hard-wearing and resilient is veneer? I could use/make thicker veneer (say 2mm) which would certainly solve this issue.
2) Blocks of wood. Quite simple to make especially with a table saw. But what about wood movement. I can see this could be a real issue, especially as you are joining different woods together which probably have different expansion rates.
3) End Grain blocks of wood. Again simple to make with a table saw, but if you want 50mm squares (as I do), you need to start with two very thick pieces of wood.
Any advice would be welcome.
James Macgregor
doctor Bob
22 Jun 2011
Matching Green
I'd do alternate veneer strips bonded to paper.
once done cut into strips again, so you have alternating square veneers, bond onto paper again.
then once done bond the complete veneer chess board to a subbase. unpapered face down. Sand off paper at the end. it's how I was taught to do them.
sammy.se
3 Aug 2014
London
interesting method!
Any particular type of paper?
Droogs
Is that chisel shar ... Ow
14 Mar 2013
Edinburgh
Re Dr Bob - at a guess probably gummed brown paper veneer/packing tape
the method you use is in the main dictated by the material used as the ground for the veneer. If I was using MDF then I would do as Dr Bob. If making the squares from solid wood then I would probably (for speed and ease) veneer a piece a bit longer and wider with each type and then run em on the saw to size and glue up and then veneer a single piece of backing veneer on the other side with the grain running in the same direction for all the parts and then do a hidden tenon mitre joint for the corners and breadboard the ends with draw board dowels.
Richard_C
17 Oct 2019
Cambridge
Whatever method you use, measure carefully and before you cut check, check, check, check ...
(sorry all, its a slow afternoon here)
Jismacgregor
4 Aug 2017
Cumbria
I was taught to make it from veneer in a similar fashion as described above. Cut 9 strips of veneer and tape them on the back with masking tape and glue them together. Making a stripey piece of veneer. Then turn it 90 degrees and cut strips. You then move each alternate strip one square north and glue together again.
My only concern is the hardiness of veneer as the customer wants this to be a working, but long lasting (family heirloom) chessboard. But I guess I answered my own question in that the solution to this is to use thicker veneer.
Now I have to find some dark veneer to use for black squares. The customer wanted African Blackwood, but my ethics won't allow me to use an endangered tree which comes from our already destroyed rainforests.
Jonathan S
15 Mar 2019
Monda,Malaga,Spain
I think someone on here had some bog oak they where selling......could look good as the dark veneer.
Sent from my SM-J530F using Tapatalk
Jismacgregor
4 Aug 2017
Cumbria
I see from your profile you are based in Gibraltar. Makes popping around to see it and pick some up a little impractical!
MikeG.
24 Aug 2008
Essex/ Suffolk border
It was me with the bog oak. I have literally tons of it. However, Cumbria isn't exactly around the corner from Suffolk......
billw
The Tattooed One
26 Apr 2009
Sutton Coldfield, UK
Birmingham actually! I will update my profile :D
