Checking a moulded or large thing for square.
ColeyS1
2 Nov 2009
The majority of the time a squaring rod with two pencil marks can be used to check the diagonals. There's several other ways , roofing square, getting someone to hold the other end of the tape measure etc etc
I'm making a large batch of windows and doors at the moment and the mould makes it difficult to measure on my own
A fairy quick workaround is to clamp a square ended piece of wood in each corner
Then hook the tape measure over it and check each diagonal
(I've added a champfer to avoid the tape wearing away the point too quickly)
You need to make sure the piece of wood sticks up the same amount, so in this instance I just kept it inline with the rebate.
There's no reason it couldn't be used on box carcasses or anything that needs to be square. I think I prefer using the tape measure for checking diagonals as it gives me an exact reading of how shoddy my work is ! :lol:
Coley
MikeG.":26cccnnm said:
You'd need two, with exactly the same chamfer.
Tis true. I used the chopsaw length stop and tilted the saw to 45 degrees. Put a 45 degree cut on each end, then chopped it in half.
Cordy":25r596u8 said:
Good idea !! :D
Thanks. Gluing up and checking for square isn't an issue now. Finding somewhere to stack all of it though......... :lol:
No you don't. You're only checking the two diagonals for equality.
Any errors in the chock pieces would be same for both diagonals.
BugBear
