FrenchIan
I should know this, having used varnish for many years, but I've always taken the lazy way out and bought tins of silk/satin or matt, as needed. But I read that satin is just gloss with additives. So, I want to use pure (gloss) varnish only, and control the final sheen myself.
I know it's done by rubbing down with eg, fine abrasive paper or steel wool (or 3M pads - I like them!). To save me making too many mistakes, can someone give me some pointers? Such as, 320 grit abrasive is too aggresive, minimum is 600 grit, or, 000 steel wool is all you need - the more you rub, the more matt it gets.
Thanks in advance
Thanks in advance
