noddy67
I'm in the process of trying to copy some kitchen chairs and so far have used sketchup for a rough model.
The rear legs have an angled straight lower portion to them and the top section is a slight curve. I plan to use some form of template setup on a router table and was interested if anyone had any pictures/plans of a suitable jig that might be appropriate. At the moment I only have a pattern router bit with the guide above the cutter. Is it worth getting one with the guide below / is that something you can just add on.
Thanks in advance
Thanks in advance
