Gitface
Hi All
Thought I'd update you all with my quest to sharpen my chainsaw blade.
After taking in the information from the last thread I got my self one of the jigs.
Looking over the instruction for the jig and the ones that came with the saw, everything clicked into place and I set about putting the file in the jig.
This is were I had the first problem, the supplied file that came with my saw is a short one so the supplied handle from the jig kit would not fit. A small issue but not deal breaker.
Looking over the angles I set the jig to the right positions and started to mount it on the bar. After a bit of fiddling I got the jig on the bar and set up. Marking the start tooth I proceeded to sharpen, rotating the blade round and moving to the stop. The procedure went smoothly and I soon had one side done. A quick change of angle and I was away with the other side.
All in all I'm impressed with the jig and after a few uses reckon sharpening the balde will be a few minutes job.
Cheers.......
Mark.............
Cheers.......
Mark.............
