paulm
IG paulm_outdoors
Having had a few largish walnut logs (not much heartwood though unfortunately) and ash logs hanging around for a while getting in the way, decided to splash on an Alaskan Mill for my larger chainsaw to help with slabbing them rather than freehanding it which can be a bit wasteful.
Went for the smallest size mill which suits chainsaw bars up to about 20". You lose an inch or so useable length from that by the time you have it attached to the saw.
Very easy to mount and dismount on the saw bar needing only to tighten a couple of clamp bolts. Used a 2x4" length of timber with a few large screws on the top of the first log, to give a straight platform for the first cut and took off a couple of inches of the outside of the log with the first pass.
After that you just use the flat surface created to run the mill on, and I decided to take a 5" slab for turning blanks, which left the other half of the log to use likewise. The mill is adjustable and you can cut whatever thickness planks you want.
Spent the rest of the afternoon with the smaller chainsaw on some of the smaller logs freehand and lugged them into the workshop afterwards. The three largest logs are left now to tackle with the mill, and then the three large ash logs in the shed, now that I've had a trial run and got comfortable with how it works and handling it.
Might not get to do any more tomorrow though, was cream crackered after this afternoon and the unexpected warm weather :lol:
Very pleased with the mill attachment, very effective and simple to use, a good buy. May need some more trees soon though :lol:
Cheers, Paul
Cheers, Paul
