chainsaw chains
Phil Pascoe
29 Jan 2012
4.35am. Pain time again :( by the bye ... anyone used these chains? They are ridiculously cheap compared to Oregon. I'm only looking at a small electric saw, so I've ordered a couple.
They might be ridiculously cheap compared to Oregon chains, but Oregon chains aren't ridiculously cheap compared with the cost of an arm of leg.
Personally, when I'm behind a chainsaw, I like a chain I can trust.
I can't see them being sold if in any way dangerous. I take your point, but I've only heard once in forty years of a chain (of any make) actually breaking and of course it's being pulled away from you and probably unlikely to do much harm. Just because Oregon are pretty much universal doesn't necessarily mean anything else is poor.
That is true, but an Oregon chain for the Stihl 025 is only £16-ish. It'll be harder and stay sharper longer, trust me. :-D
You've used the Rotatechs? For the price of an Oregon you could use one and carry a spare. I have liked to carry spares since one morning I sharpened four chains three times each. (freehand - no jig! :D ) A four foot diameter macrocarpa 100 yards from the sea was the culprit.
A quick google reveals that these used to be sold as Piranha chains. There's a discussion thread about them here. Experience there seems to be mixed, with some good and some bad. For the price they're certainly worth trying.
As for chains snapping - I know of 3 occasions at work in the last 5 years or so. All were either flung forward or caught by the chain catcher.
We buy our chains from the local dealer and they come boxed but I couldn't say if they've been made to length in store. I'll ask next time I'm in
phil.p":23746vrs said:
Yes, that's the site Duncan pointed me to. Some useful info. there.
Ah yes. Missed that.
How does one post a link but only have the words "here" showing?
Hover over the URL button in the "Full Editor" and you'll see the format.
Code:
Insert URL: [url]http://url[/url] or [url=http://url]URL text[/url]
I have been using an Oregon PowerSharp chain and sharpener on my Stilh for about three years now without a problem, the good thing about the PowerSharp is that you don't have to wait until you have to sharpen the chain, just give it a few turns in the sharpener stone clamp after a short while then carry on, it gets a lot of use by the way and I have not worn out the chain yet.
Link: https://www.oregonproducts.com/pro/prod ... terKit.htm
Mike
I use 4mm Dremmel stones in my knock off Dremmel
They are about £5 for 3
A stone will sharpen 6 or 7 times
The trick is little and often (as with much in life)
MMUK":1w9gnc8t said:
FWIW, I usually buy OEM branded chains, or failing that an Oregon.
Don't think you can get better than Stihl followed closely by Oregon. I would not worry about OEM chains unless it was one of the above. Not saying they won't be OK and think Oregon make for others but you are safe with these two.
