Castor wheel
dickm
25 Oct 2004
North of Aberdeen
Recently got the chance of a very reasonably priced electro-hydraulic log splitter, to ease the task of splitting the wood from the five fir trees. Seemed to work well, but was a bit of a pig to move around, as it's heavy and the single leg has an unerring aim for ankle/shin when moving it. So with £1 worth of steel tube, some steel strip left over from building a weaving pole set-up for daughter's agility dog and a biggigh castor from who knows where, produced this. Welding is very untidy, and it still needed a bit of work when I took these pics, but it's one heck of a lot easier to move.
Then today managed to fall out of apple tree, so won't be heaving logs around for a while!
Sorry, just had to post this link when apple tree got a mention. Plus it's in my head at the moment because my wife is practising the flute part in an arrangement for a (very) amateur local villages wind band I live in a village called Newton, where we know a great deal about apples and gravity.
Hope you feel OK soon.
I bought one a few years back and, yes, it’s literally a bl**dy pain to move around, especially on our very uneven garden.
Keep promising myself to add wheels but another one of those jobs I haven’t got around to 🙄
Well done for doing yours…..here’s hoping 🙂
Do we get to see the self lifting function, or is it for your eyes only? ;)
Sadly, no self-lift, so it still has to be lifted by me in order to flick the wheel down, but at least it doesn't snap at ankles with a straight lift. Now, suppose it would be possible to slip a small car jack under the bottom bar....? Will think about that.
Dick
Does the thing not go up n down?
Er... what "thing"? The castor wheel is on a stem, pivoted at its upper end. Lift that end of the splitter, push the castor stem out and down and put a pin through the outside to hold it in place. I suppose a long lever attached to the stem somehow COULD be made to lift it (I have one for the Lurem universal and a similar one for the massive router table). Probably not worthwhile in this case as it's more the awkwardness of the splitter than its absolute weight.
Only jokingly suggesting what you said,but thinking some old tree trunk or whatever sketchy thing might have been utilized.:eek:
It's one of the more interesting takes on the retractable caster solution that I've seen.
Tom
Thanks for the compliment! In the wee small hours, it occurred to me that a heavy strap hinge or something similar could be welded to the side of the pillar furthest from the frame, and used as a handle to lift it. Could then be folded away under the frame. Maybe in a month or two.......
Thought: Would the mechanical advantage of some form of lever with fulcrum be easier than a handle and deadlift?
Definitely. I've been mentally designing something which shouldn't be too difficult to make (once I'm mobile again!) but not sure how it will "feel" in action, as at some point in the raising process, the thrust on the castor may want to move the whole thing forwards, rather than a clean lift. My maths and mechanics/kinetics aren't up to checking the theory.
(Many years ago, was critical reading some stuff by a colleague which included the line "draw the mechanism and analyse its motions". To a agriculturalist taking faecal samples, that means something rather different from what he intended!)
Chock / wedge under the castor to limit movement while you lift?
Given right 'aid', a ledge under which you can rest the bar while you drop the castor (unless you can free it to drop while you're lifting?)
Both excellent ideas. The first, when I get "a round tuit", MAY not be needed, though it'll probably be easier to put a long chock in front of the two non-swivelling front wheel, not the castor. The second is basically what I've got for my Universal and router table, and work well. So getting to be spoiled for choice. What is done will probably depend what I can find in the "come in useful sometime" drawer! And the restoration of ability to bend, move around etc. without squawking!
Reminds me of the mechanism on the front of my rotovator, the arm holding the wheel (caster in your case) has an elongated hole at the pivot to allow it to slide in and out of two positioning grooves in the side plates, one up, one down. The pin that locates in the grooves is fixed through the arm and holds one end of the spring which pulls the arm back against the pivot keeping it firmly in place.
Hope you are feeling better soon, may be safer to let the apples come to you next time.
Couldn't help thinking of this
Yes, wondered about something like that, but decided my chosen design was "better". or more accurately, was easier to make with welder and power hacksaw!
Think the plan is to let ex-mountaineering son-in-law do the climbing, in exchange for a tithe of the apples! Been getting very ferocious comments from SWMBO. With which I have to agree, as it's taking a heck of a time to start feeling better!
DickM
I've had mine for years and just left it beside the log stack with a bulk sack slung over it. The rubber wheels have now perished so won't be moving mine anywhere...
Brought to mind the 30", pretty much unguarded, circular sawbench that lived uncovered outside our then farm. Driven by a long flat belt by a 1938 John Deere. Interestingly, it didn't ever seem to rust. Wonder if it was so coated in resin etc. as to be protected. Probably fortunate I was too young to be allowed near it, given my record! Wonder where it is now.
Having regained mobility after the apple tree incident(!) decided to try out an idea for lifting which save either using a jack or doing contortions lifting with one hand and pushing the castor wheel down with the other. This is the thing assembled, obviously still in need of tidyingn but it works and doesn't seem to get in the way.
