Car boot haul - restoration begins
jadboog
15 Mar 2010
Cardiff
Great haul for £16!
Left to right:
2 x spirit levels
wooden handled clamp
square file
chisel
bradawl
screwdriver
saw set
10" 11tpi dovetail saw - reads 'Ward Sheffield' on the handle
20" 9tpi hand (?) saw - Spear and Jackson 'Spearior' - what is the dowel coming out of the top of the handle ?
24" 7tpi crosscut (?) saw - nothing on it.
24" 6tpi rip (?) saw - Spear and Jackson
Any help / more info on the saws ? Suggestions on restoration also appreciated.
    248.5 KB
The screwdriver looks like a gunsmith's turn key (Screwdriver), while Spearior "88"'s are excellent professional quality saws. The rod and dowel through the handle is a sound type of reinforcement and - regardless of what some may think - is a solid means of ensuring a saw handle remains undamaged throughout the saw's working life. Especially if used for construction site work.
Your Ward tenon saw looks like it could be a good user once cleaned up. :)
Hi, jadboog
That middle handsaw is the best, S&J I think I have a incremental rip saw with just the same handle.
They all should be good users, the dowel should tap back in the the handle.
Nice haul.
After just over a year I finally got round to restoring some of the tools above.
I thoroughly sanded the gunsmiths turnkey, hammered it back into shape and tidied up the head with a file. I gave the handle a coat of Liberon medium Oak dye before a few coats of varnish.
The saw is the Spearior. I sanded the handle gently but couldn't save the 'Spearior' lettering. A few coats of Ronseal quick drying walnut varnish finished it off nicely. I polished the brass with sandpaper and lapping film offcuts and was pleasantly surprised how well the medallion came up. I hammered a few kinks out of the blade after cleaning it up then flattened, sharpened and set the teeth. Really pleased with this first attempt - the saw cuts well, looking forward to restoring more!
    42.9 KB
Well done for getting the kinks out of the blade - speaking from experience, that's not easy to do neatly!
Two tools there that should now give many years of good service - splendid stuff!
