80 years old and can't varnish--- what am I doing wrong--- Sanding down to 400-- finishing with wire wool -- one coat -- sand --- 2 coats --- sand third coat--- dry ---- rubbish---no shine/ gloss at all--- Help!!
MusicMan":3797hv33 said:That looks good Custard. Are you willing to disclose your varnish formula, or do we have to resort to industrial espionage/threats/bribes????
Isn't this the problem right there?jonluv":1jeyg8jx said:... sand third coat...
custard":scnjrscm said:MusicMan":scnjrscm said:That looks good Custard. Are you willing to disclose your varnish formula, or do we have to resort to industrial espionage/threats/bribes????
There's no secret. Roughly equal quantities of a good oil varnish, thinners, and an oil. If you want it too dry faster reduce the oil. If you want a faster build increase the varnish. This is what I use,
but there are loads of recipes out there, and I don't think mine is any better (or any worse) than most of the others. It's simplicity itself to rag it on (as I said before though, dispose of the rags properly) and if you want more gloss then finish with a wax, the harder the wax (i.e. the higher the carnauba content) the shinier the finish but the harder work it is to buff up...you pays your money and you makes your choice.
There's a lot of voodoo surrounding finishing. Most of the basic finishing techniques are no more difficult than making an omelette, but to listen to some of the nonsense you'd think it was alchemy. It's yet another woodworking rabbit hole that you don't want to fall down. Get three or four basic techniques under your belt, consider which one is most appropriate for any given project, then just crack on and do it.
Incidentally, the timber in the previous post was American Black Walnut, which varnishing and time warms up considerably. Before the unpleasantness of 1776 this country used to import loads of ABW and a fair bit of it was varnished. Consequently you'll often find antiques described as Mahogany when it's really varnished ABW.
mbartlett99":38998zjk said:Hey Custard - whats the tung oil for?
By 4th got good solid gloss and a bit of depth and grain on teak has nearly filled with perhaps one or two patches. For full yacht finish continue to 8 coats with a good flatting back. And I would definitely use Epifanes for anything exterior.
phil.p":1hfh5lvl said:My eyes are getting worse - I read it as Carrot Varnish. :lol:
<Google Translate> Even though I'm a furniture maker, I've discovered that people who can afford horses, and all the kit that goes with them, are used to paying good money.</Google Translate>custard":35m4a9t8 said:Here's an example, even though I'm a furniture maker I've got a useful sideline in making high end "equestrian furniture", stuff like saddle stands, bridle racks and mounting blocks in inappropriately expensive timbers for posh stables!
