rafezetter
Troll Hunter
I picked up a shoulder plane at Richard A's charity do last year and only came to use it a week ago.. or try to anyway.... Andy T, I took the bullet on this one it's a dog.
Sides are not even close to flat, either top to bottom or end to end. One one side I'm guessing where the maker peined a fixing stud he went way too heavy and dented the side above right above the mouth.
The blade bed isn't particularly flat either, and the blade stem... double banana.
However... all that said it's made of stainless, large at 230mm x 67mm and pretty heavy.
So I was wondering how hard would it be to dismantle, make a new plane bed (he says...) bang out the worst of the wavy sides especially the dent, and pop it back together...
My biggest concern obviously is, can dovetailed sides and base be prised apart, then re assembled / peined?
If not.. any possible suggestions on how this plane may be retrieved?
I've considered drilling out the studs, then slipping the body onto my I beam "anvil" to see if it can be reduced by hitting the area around the dent, and I've also considered adding false sides from brass or something - I've got about 2mm extra clearance down the blade "throat" to fit a wider blade - as it needs a new one anyway, but I'm not sure how to deal with that dent as it would still show at the top.
Another option was to linish it - but don't have a flat enough bed to do that, tried by hand... got almost nowhere, and I'm not skilled enough to do it on my belt sander - I tried last night but found it very hard to keep it flat and level - plus with the depth of that dent, by the time it was out, it would have left the sidewall at that point very thin.
Or I could just slap some epoxy resin on the sides, then flat it on glass; at least it might be useable then, but that just feels like tool rape...
thoughts anyone? (apart from chuck it away - I'd like to at least have a go...)
