A
Anonymous
Guest
I really need to get my dust collection under control. Currently I'm using a shop vac type vacuum cleaner with power take-off to collect dust from my table saw, router table, chop saw & ROS. I have the tools plugged into the vac via a 4 way extension lead and I move the vac nozzle around and 'plug it in' to each machine as necessary. It would be a good system if the vac had more suck!
I'm thinking of buying a Camvac and knowing that some of you have them, I was wondering what you thought of them versus the similar Record products? In particular do I need to buy the twin motor version or is the single motor plenty good enough?
I plan to invest in a fixed vacuum line with blast gates and stuff in the near future. The neatest way would be a 'horseshoe' arrangement with about 13 meters of main pipe run and branches of of it. Should I use the 65mm diameter pipe or the 100mm soil pipe? My workshop is small, about single garage size, the small stuff is cheaper and I am a weekend hobbyist.
TIA
Wulfric
TIA
Wulfric
