dansmith
Hi,
Can anyone recommend some good quality stainless steel cabinet butt hinges? They are to be used on 19mm frame (kitchen) so I assume they will need to be around 63mm x 38mm. I have purchased a few hinges of this size in the past but they always seem low quality with poor movement. Ideally I would like ball baring hinges but i don’t believe they are available in this size. A few of the doors I will be hanging are quite large around 85ishcm x 65cm so I’m also a little worried about the weight. Do you think I should consider increasing the frame to 27mm to allow for larger hinges?
All advise and recommendations are much appreciated.
Dan
Dan
