Budget HVLP Paint Sprayers - Does one exist
Skeety
4 Feb 2014
Berkshire
Hi All,
Yet another question..... With some of the projects i'm doing currently I'm thinking I could get a better finish and achieve it quicker with an HVLP System.
I have seen basic ones in the £40-£60 range on fleabay. Normally don't skimp on tools but don't have any option apart from a budget solution at the moment. If the option of a budget solution isn't an option then I will continue to hand finish.
I'm mainly looking to spray MDF Sealer, Gloss and Blackboard paint.
Can any of you offer any advice on the HVLP paint systems, things I may need to consider that I haven't thought of etc. How much hassle is it to switch between paints?
Cheers,
Jon.
I bought the Erbauer one recently. I was painting a load of MDF that had a tongue and grove finish on it and it was a pain to paint so I nipped out to screwfix and picked up the Erbauer one. I had to thin the paint a little (it was waterproof Cuprinol) but when I did that it worked really well and gave a great finish. I seem to recall it was about £40?
Cheers Stu,
Have spent the last 24 hours reading reviews etc. from cheap systems right up to semi pro. The Erbauer only seems to have a couple of bad reviews on Screwfix which i'm leaning towards them not having RTFM! or expecting it to paint a 4 bedroom house without a break.
Will get one of these I think and see how I get on with it, if it's rubbish it can go back :)
Cheers,
Jon.
Cheers,
Picked one up today, need to pick up some suitable containers for storing my thinned down paint but will post results definitely :)
Think it may be an idea to keep an Excel sheet of different paints and how much to thin them. Obviously the same paint from the same manufacturer :)
Jon.
Please do tell us how you get on as I've been looking at these too.
Couldn't decide on something like the erbauer hvlp, a small electric sprayer or something to go on my compressor so ill be interested in your findings.
Edit; can these spray satin wood paint?
Will hopefully get chance to try it out before the weekend.
MDF primer i'm pretty sure will need thinning 30-35% with water, blackboard paint probably the same but with White Spirit.
Have sprayed in the past, 20 odd years ago so most of the fundamentals should apply. But this time I won't be high on Cellulose thinners after painting a car or bits of it lol.
Jon.
