xy mosian
Hello all,
I am a hobby woodworker these days, for enjoyment, and occasional pint. In recent years I have made the odd chair, and stool, in the Windsor style.
No matter how I try there is always a leg which is not quite at the correct angle. This guide is an attempt to help with said problem.
I hope you can see that if the distance between the vertical surface, of the guide, and the hole centre is repeated so will the angle of the hole. There is a notch, saw cut, at the bottom of the vertical surface and this is repeated at the back. This is for alignment with the 'sight line'. Platform height will allow the auger to be used vertically if needed.
In use set the angle of the auger, by any method, slide guide into contact and clamp down. Measure the distance between the hole centre and the vertical surface. For other holes of the same angle mark that distance, along the 'siight line', from the hole centre, clamp the guide down and drill the required hole. There is clearly a limit to the hole depth possible, but a correct angle of start is assured.
The elastic band is merely to hold the auger in place for the 'photo.
Comments please,
xy.
Comments please,
xy.
